SC engine won't hand turn after cylinder install
Hi all,
odd question at least from me as I have never done this before. A friend who has torn down a few water cooled (997/Cayman) engines asked for my help reinstalling pistons and cylinders on a basket case 84 911. I came in for an extra set of steady hands reinstalling cylinders/pistons and wrist pins. All went back together pretty easily. now engine will not hand turn past 45-90 degrees in either direction without a solid metal clink at the end of travel. we did run into this a bit on piston install but it was always the rod shoulders hitting the case because we had a hard time keeping unladen rods centered in the bore as we rotated the crank. We'd simply back off a dight, recenter the piston and continue. Now with all cylinder and piston on the crank has very limited rotational movement. I'm sure there is something, hopefully simple, that he/we missed. thx https://youtube.com/watch?v=X1zLxdMbXv4&feature=shared ![]() ![]() ![]()
Are just the cylinders on, no heads bolted down?
1986 Targa Guards Red 2021 MT09 SP |
I am no expert, but I would say your timing chains are getting kinked-up and not letting you turn the crank. Just a guess on my part.
Hope this helps. Good luck.
Ed Paquette 1983 911SC 1987 944S 1987 944 Manual (Donated to the Nat. Kidney Foundation) 1987 944 Automatic (Recently sold to another Pelican) |
Yes, seems like a chain kink but they are free and clear. When cranks "hits" limit, very metallic clunk from below the crank but hard to source side to side. Just pistons and cylinders thankfully, no heads yet so no blockage at top of pistons
Was the case split during this rebuild?
You aren't binding up on the engine stand? BTDT
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
Case was split and engine was taken totally apart, and cleaned at machine shop. All new crank bearings and rod bearings, rings, seals, cylinder studs.
Original rods, pistons, cylinders, wrist pins as they were in great shape. Piston, rod, cylinder placement, triple marked, checked and as original. Engine is on a stand. Not sure how you get this far any other way? |
Are timing chains hanging with sprockets on them? I would double check timing chains they can sometimes fool you and what your describing sounds exactly like a kinked up timing chain.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
yes, hard to see in the picks but both sprockets hanging from chains and turning. Agree that it seems like a chain kink. But anyone whose done this or been around chain drive motorcycles knows the sound of a metal chain kinking on an alu or similar case. This is a hard metal clunk. Of course volume dependent on how hard you rotate the crank. If not solved may try to get a vid this week, though time in the shop is at a premium for a while.
+1 on timing chain(s) kinked on the inside part of the gear. Feels hard metallic when it happens. Might want to get a borescope tool in there and take a peek.
Not in your case, but aftermarket rods will hit the oil pump, necessitating grinding some clearance in the oil pump. |
https://youtube.com/watch?v=X1zLxdMbXv4&feature=shared |
That video is so short and cuts off so soon it's difficult to analyze.
It looks like 2/5 journal jumps at the clunk. Need to watch this in slo-mo... Edit: in slo-mo the #2 rod moves much more than the others and seems to coincide with the knock sound. Last edited by 917_Langheck; 04-01-2025 at 04:19 PM.. |
measure from the chain housing surface on the case to the same point on each sprocket and whichever is shorter, that's the bound up chain.
I appreciate it is short, but the crank only rotates ~45 degrees. Nothing to see before that, or after as it's stuck. I can say on the vid, all the rods you can see are free in the case, i.e., the shoulders are not catching on the inner case.
You have rod bolts installed upside down.
Cylinder one you have the rod bolt upside down, nut goes on top.
well spotted!
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
Wow, so apparently I misspoke when I said everything was put back together as original!
That makes all the sense in the world (not only because I was not on the tear down team!) as the interference was both seeming minimal and very metal on metal, and the rod bolt "keepers" did not seem to engage their reliefs as well as i thought they should. All are installed incorrectly! If so a very straight forward fix. Much appreciated all! ![]() Last edited by 87m491; 04-02-2025 at 08:44 AM.. |
