Try not, Do or Do not
Old School Porsche Fun
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Very cool Henry, that motor just screams. Thanks for sharing.
1974, 914-6 GT Tribute 2007 Cayman S 1998 993 Carrera S, speed yellow (Yellow Bird) gone but not forgotten. 2017 Golf Sportwagon 4motion Exclusive source for the 914 Umbrella and Service cover |
What a wonderful car - motor sounds angry. It looks really well done -
Tonger |
PCA Member since 1988
The top is still steel?? Gotta replace that with carbon...
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Very nice my kind of ca
What’s the spec on that engine you supplied Henry ?
Do you have records on the build you can share ? It sounds like heaven ….. |
Edit: I can say it was probably 18-20 years ago. I am surprised that it wasn't equipped with our cold start enrichment device. We've been supplying the enrichment devices for 25+ year in with none stop development, so if it had one installed that would also help identify the approximate year.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 04-13-2025 at 08:24 AM.. |
This short stroke 3.2 was built in 2017 for Scott Longballa.
Note the enrichment device and aluminum fan center. These fan center were incorporated in most of our high RPM engines of that era. The stacks were modified to use PMO 50mm velocity stacks. This allowed us to bore the magnesium MFI stacks from 42 to 50mm. This engine also used the Supertec/Burnham distributor like the engine in the video. Note the Supertec fuel lines as well. ![]() Many of the development items on these engines were proto-typed on a first 2.8 short stroke built for spirited street driving. You might recognize this engine from the cover of Wayne's first book.
Ben M. from M&K made a rather interesting exhaust for this project. It's always fun looking through old history.
That looks loud.
About 92 DBs WFO but a mellow sound, very little rasp.
I stumbled across some info on the engine when you originally built it in December 2007 , or more likely Jan-feb 2008 . (Ref: ph-3.0) Originally it was equipped with your old fart enrichment device .
Your engine in the ST build sounds wonderful and looks very cool..
Bert Jayasekera 1970 911T - Tangerine Orange Early 911S Registry #494 R Gruppe #167 |
Super cool..
Stunning! Absolutely love the clean engine bays
mine definitely needs some TLC
