Is a "service loop" for alternator wiring a good idea?
Hi guys,
Making progress on getting my 3.4 into the car - far slower than I expected. Just doing the engine wiring harness now, particularly the alternator wiring. I recall replacing the alternator on my previous 911 was a huge PITA as the wiring harness was so short I could barely get a wrench in there to loosen the connections while holding a heavy alternator in one hand. So, I am thinking of putting a generous loop of extra wire that would tuck up against the shroud (might 3D print a hook for it) and then if I ever have to get it out, it should be much easier. Here is the service loop I have in mind. ![]() I can't think of any downsides...can anyone else? Thanks all, D. |
No downside in my eyes and worth a try, but how stiff are your wires that you can make such an angle like the blue one?
On the other hand: How much you think you have to remove/replace alternator? Once all year or ten years?
Roland 930 Turbo '81 Too many modifications to list |
I upgraded the wire considerably, its either TXL insulation which is pretty bendy with multistrand wire and the large ones have high temperature silicone insulation and are also multi-strand (like 300 strands). Thanks again! D. |
Considering the tuned guitar strings Porsche wired into the 911, any extra wire added will pay dividends in lower frustration levels during future service or adjustment work.
I think I would just add enough extra to get my wrench on it when I pulled it clear of the shroud.
Rutager West 1977 911S Targa Chocolate Brown |
Thanks everyone for your help...much appreciated. D. |
Anything that spares you from holding a 20-pound alternator in mid-air like you're defusing a bomb is a win in my book.
I think it is going to work out well. Now with my luck, this alternator will be rock solid and never die....and I will never need the loop. Ah well, next owner after I croak... D. |
PCA Member since 1988
"Now with my luck, this alternator will be rock solid and never die....and I will never need the loop."
I'll take your luck!
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
