Belmetrics - Cross Reference Part Numbers?
Anyone cross references OEM Porsche part numbers with Belmetrics?
Just thought I'd ask, was about to try and figure out exhaust studs for a 3.2. I'm hoping someone here is going to dump info from an amazing spreadsheet they had saved :) |
There is no cross-section between Belmetric and Porsche part numbers
For your 3.2, the studs are M8 (fastener diameter) x1.25 (thread pitch) x45mm (length) Regards, Yasin |
Porsche studs follow the DIN 835 standard. I believe this is the one you'll want...
https://belmetric.com/m8-double-ended-stud-din-835-class-8-8-steel-m8/?sku=S8X46DYLW http://forums.pelicanparts.com/uploa...1750106980.jpg |
Use the PET to confirm the sizing -> then look that up on BelMetric: https://www.dropbox.com/scl/fi/9y6qu8xkb8xk6jp7w7545/911-pet-84-86.pdf?rlkey=myworxnctkejn34kol8f5mduy&st=vstdgvxm &dl=0 (start with page 149 of the PDF / illustration 202-05)
PET shows M8 x 40. |
| All times are GMT -8. The time now is 04:59 AM. |
