Belmetrics - Cross Reference Part Numbers?
Anyone cross references OEM Porsche part numbers with Belmetrics?
Just thought I'd ask, was about to try and figure out exhaust studs for a 3.2.
I'm hoping someone here is going to dump info from an amazing spreadsheet they had saved
Old 06-16-2025, 07:52 AM
There is no cross-section between Belmetric and Porsche part numbers
For your 3.2, the studs are M8 (fastener diameter) x1.25 (thread pitch) x45mm (length)
Regards,
Yasin
Old 06-16-2025, 09:28 AM
Regards,
Yasin
Thank you!
Old 06-16-2025, 11:26 AM
Porsche studs follow the DIN 835 standard. I believe this is the one you'll want...
https://belmetric.com/m8-double-ended-stud-din-835-class-8-8-steel-m8/?sku=S8X46DYLW
Ward Komers
1984 944 Track Car - Sold
1968 912 Rust Bucket - Under Repair
1971 911T - Under Repair
2006 Carrera S - Sold
Old 06-16-2025, 01:51 PM
Use the PET to confirm the sizing -> then look that up on BelMetric: https://www.dropbox.com/scl/fi/9y6qu8xkb8xk6jp7w7545/911-pet-84-86.pdf?rlkey=myworxnctkejn34kol8f5mduy&st=vstdgvxm&dl=0 (start with page 149 of the PDF / illustration 202-05)
PET shows M8 x 40.
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings)
Dynamic CR calculator: https://dcr.questionable.services/
Gear Ratio (Speed @ RPM) calc: https://ratio.questionable.services/
Old 06-16-2025, 04:47 PM
