Porsche Crest 69 911t 2.0 Need recommendations
Hello All,
I need some advice and or recommendation on my engine rebuild. I have a 2.0 l engine. I took apart and I do have a couple of issues. 1st I have never worked on a Porsche. I seem to have a head bolt that needs to be repaired, 2 pistons have chipped (see pics) other than that I don't know what I should be doing to get this car going. I would like to take it to the track some day and have some fun with this car. I don't need to keep everything original....Just want to have a fun car to drive.
Old 07-17-2025, 03:56 PM
Constitutional Liberal
Turbo_pro's Avatar
First buy Wayne's book from our host and then grab your ankles.
Jim
“Rhetoric is no substitute for reality.”
― Thomas Sowell
Old 07-17-2025, 04:17 PM
This is the book from Wayne which is being referred to. It is a must read, there are some corrections see the sticky thread at the top of this index.
There is a bit more to it with the magnesium engines than just fixing a head stud issue. It's explained in the book about all the things you need to do to a magnesium case....but I will also add they are known for case sag and need the cases trued where the spigots are (where the cylinders sit). I cant remember if that is in the book or not. I learned it from the Nick Fulljames engine series.
Old 07-18-2025, 05:49 AM
I would recommend Bruce Anderson's book . And Ollies once told me that in 30 years they have
seen maybe 3 mag cases that were not warped . So between Ollie's and Nick Fulljames , your case is most likely warped .
Old 07-29-2025, 09:05 PM
i had the 69T bad engine cross roads and my engine builder friend begged me not to go down that rabbit hole and talked me into a used 3ltr.
Banda
69 911T 3.4 ltr. Outlaw build
72 BMW 2002ti Alpina "Pig Cheek" build
Old 07-29-2025, 09:13 PM
PCA Member since 1988
I'll 2nd what Banda said, and I did. If you are not concerned about originality, then go with a 3.0 or 3.2 engine. More expensive up front, but less expensive overall.
Very important question: What's your budget? Have you owned this car for several years, or are you new to the sickness? How is the rest of the car?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 07-29-2025, 11:15 PM
