-   -   Rocker shaft locator lock (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1180581-rocker-shaft-locator-lock.html)
Flat6pac 07-23-2025 10:45 AM
Any info will be helpful. I’ve seen mentioned several times but until I had to use a breaker bar to release the rocker shaft yesterday, I figured in the past rocker shaft seals were the answer.
I recall it’s a private company’s design but I can’t reference the company in any postings
Thank you for the help,
Bruce
Henry Schmidt 07-23-2025 12:28 PM
I think this is what you are asking about.
https://parts.turbokraft.com/collections/911/products/rocker-shaft-lock-set
http://forums.pelicanparts.com/uploa...1753298883.jpg
Flat6pac 07-23-2025 02:03 PM
Thank you Henry, read about them, never needed until now…
Bruce
