3.2L case perimeter studs- cannot find a source
After much searching (Porsche OEM, McMaster-Carr, internet, all other vendors) I cannot find a source for the M8 studs around the perimeter of my 3.2 case.
Our host says not available, and McMaster and others do not have studs that match the original dimensions- what are you guys using for replacement studs? If I am reading the Porsche Catalogue correctly, these are "M8 x 32" PN 999 062 115 02. Not sure what the 32 is referring to- no part (or any combination) of the stud dimensions equals 32mm. My Measurements: short threaded end: 16.5mm Long threaded end: 23.5mm unthreaded shank: 8.5mm Overall length: approx 48.5mm (Some of my studs have enough corrosion that I would rather not clean them up and re-plate) Any help appreciated! Thanks, Dave
Dave Project: 1985 Porsche 911 Carrera Coupe 3.2 to 3.4L "Carina" PCA Member- Sacramento Valley region |
The 9 Store
My go-to is usually stoddard or belmetric. I’ve ordered a lot of stuffs lately from stoddard and they have about 75% of what I need. Not great but it’s better than nothing.
All used parts sold as is. |
Porsche use to identify stud length by what’s showing, so the part threaded in to the case is not counted. Don’t know it it’s still that way.
Global Metrics is a good source.
See below for info on studs. Bel metric is a good source for DIN 835 studs. I’ve also been able to source studs from our host and rosepassion.com.
Ward Komers 1984 944 Track Car - Sold 1968 912 Rust Bucket - Under Repair 1971 911T - Under Repair 2006 Carrera S - Sold |
Thank you! I had tried Bellmetric before I posted this thread, but apparently I didn’t select all of the correct variables - I went back with the measurements that draw provided, and there were the studs- for $1.70 in yellow cad.
Rose passion is a nice site too- it’s too bad they are across the ocean from me. Describing a stud according to it’s Installed height is something I haven’t seen before. Global Metrics doesn’t appear to have a website, but I can call them. |
Rose passion will get parts to you just as fast as states based companies. I use DHL for shipping.
