Case through bolts: torque dry or wet?
I have the Bentley Manual and Wayne’s book, and there is no mention of lubricating the threads of the case through bolts prior to torquing them. But I have watched some seasoned Porsche engine builders lubricating these threads prior to torquing….
Searched the forum and found nothing regarding this, other then you should not use any product on threads unless the manual calls for it. Increasing the clamping force can be a good thing or a bad thing, depending upon a host of variables…. I am curious what other builders are practicing. Thanks, Dave
Dave Project: 1985 Porsche 911 Carrera Coupe 3.2 to 3.4L "Carina" PCA Member- Sacramento Valley region |
Try not, Do or Do not
We always coat the green o-rings with Dow 55 and coat the threads with Supertec assembly lube. Any high quality assembly lube will work.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Thanks Henry!
If you don't use something on them, you'll get the squeaking and cracking noises that'll make you question anything about proper torque. Listen to Henry.
Not to toot my own horn....but, who else has their own assembly lube....
It's not for sale but we do some goofy stuff. I designed the products based on an additive gleaned from the SkunkWorks (FOIA) and the engineer who mixed it for us died taking the formula to his grave. We'll use what we have left and then poof....it's gone.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 08-26-2025 at 01:19 PM.. |
Cool…..
