fallingat120mph's Avatar
Heat sink compund question for ignition module...
As stated in another thread here I am building a 3.4 engine and using the ignition module from a 993 system. Just wondering what people recommend for the module to heat sink connection.
I found the below but wonder if there is better?
Any info is appreciated-
Thanks!
Erik
1986 911 Coupe
1986 911 Targa
Old 09-11-2025, 05:38 AM
1986 911 Coupe
1986 911 Targa
Old 09-11-2025, 05:55 AM
Hi
I believe that genuine Dow Corning 340 material is good for your application and I have used it for a similar application.
See link to dated TDS below.
However I note your picture states "Brand HushOil"; I would not use that stuff.
Cheers
https://ecommapi.krayden.com/Content/pdf/datasheet/dow_340_tds.pdf
Old 09-11-2025, 11:52 PM
That giant tube is way, way too much, both in cost and amount.
Get the heat sink compound from Arctic Silver or Super Lube.
If you know a professional mechanic he probably has a few packages of the compound in his tool box left over from replacing ignition modules and would likely give you one for free.
Old 09-12-2025, 04:19 AM
Originally Posted by Magyar Kiwi View Post
Hi
Cheers
Yeah not sure about the "brand" as you point out. I will see when it shows up what really comes in the package.
Thanks!
Erik
1986 911 Coupe
1986 911 Targa
Old 09-12-2025, 02:56 PM
I did see those earlier but the instructions/install called for the Dow/Dowsil(?) if memory serves. So I went with that. Looks like I am good for the next 20 years!
Thanks and at least now I will know to pass on to others.
Erik
1986 911 Coupe
1986 911 Targa
Old 09-12-2025, 02:59 PM
