Heat sink compund question for ignition module...
As stated in another thread here I am building a 3.4 engine and using the ignition module from a 993 system. Just wondering what people recommend for the module to heat sink connection.
I found the below but wonder if there is better? ![]() Any info is appreciated- Thanks! Erik
1986 911 Coupe 1986 911 Targa |
Hi
I believe that genuine Dow Corning 340 material is good for your application and I have used it for a similar application. See link to dated TDS below. However I note your picture states "Brand HushOil"; I would not use that stuff. Cheers https://ecommapi.krayden.com/Content/pdf/datasheet/dow_340_tds.pdf Last edited by Magyar Kiwi; 09-12-2025 at 03:07 AM.. |
That giant tube is way, way too much, both in cost and amount.
Get the heat sink compound from Arctic Silver or Super Lube. If you know a professional mechanic he probably has a few packages of the compound in his tool box left over from replacing ignition modules and would likely give you one for free. |
Yeah not sure about the "brand" as you point out. I will see when it shows up what really comes in the package. Thanks! Erik
I did see those earlier but the instructions/install called for the Dow/Dowsil(?) if memory serves. So I went with that. Looks like I am good for the next 20 years! Thanks and at least now I will know to pass on to others. Erik
