Porsche Crest Help! 911t 2.0 piston upgrade? Help!
Can I install 81mm, 2.0L Pistons and cylinders with Compression ratio is 9.5:1 with the 66mm crank on my stock 911t 2.0? Do I need to change the crank? Camshaft...i don't know what to do. My old pistons/ cylinders have broken parts.
Old 09-07-2025, 03:42 PM
Rosco_NZ
Send a message via Skype™ to Rosco_NZ
Your engine is a SS 2.0, 80x66 mm crank. Yes, 81mm and higher compression would be a nice upgrade. But keep an ear out for pinging, you might need to run better gas.
Old 09-08-2025, 11:45 AM
So I don;t need to change the crank on my 911t 2.0? Is 91 octain gas ok?
Old 09-08-2025, 12:38 PM
Be aware , a 9.5 to 1 CR may be too much with T cams . What will the dynamic or actual CR be as opposed to the theoretical ?
Old 09-20-2025, 07:43 PM
If standard 911E 80mm 9.1:1 would work for you, I still have these. Make an offer.
https://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1161671-69-911-2-0-e-pistons-cylinders.html
66 911 club racer
Old 09-21-2025, 10:09 PM
