-   -   Trying to source a 3.2 replacement vacuum line rubber reducer (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1184215-trying-source-3-2-replacement-vacuum-line-rubber-reducer.html)
85RedCarrera 09-26-2025 04:59 PM
I had to remove the rubber reducer on my vacuum line on my 3.2. It was split, so I cut off the steel crimp and thought it wouldn’t be a big deal finding a suitable replacement, but everything I have looked at this far is not a good fit. The straight rubber reducer on the oil tank (pictured below next to the taller reducer I need to replace) is a fairly close match, but the larger ID is way off, and I think it would be too short anyway. Bummer Porsche only sells the reducer when you buy the whole line with it!
I can surely Frankenstein something to work, but was hoping that somebody may have already done this and found a suitable straight rubber/silicone reducer to use. Seeing as it’s for vacuum, the wall thickness needs to be relatively stout to keep it from collapsing. I could also braze a short extension with a larger OD so that I could use the oil tank reducer I bought.
Any ideas appreciated!
http://forums.pelicanparts.com/uploa...1758930737.jpg
Turbo_pro 09-27-2025 08:45 AM
I've had problems like that on turbo installs and we cured it with an adapter sleeve made on the lathe from aluminum bar stock.
85RedCarrera 09-27-2025 09:05 AM
Yeah, I may have to go that route. I was hoping to find an off the shelf item. After 1.5 hours perusing vacuum fittings online, I realized that I could have fabricated it and been done already!
Flat6pac 09-27-2025 09:45 AM
Slip one fuel line piece inside a larger and add some avation permatex for a seal and clamp the ends.
mikedsilva 09-27-2025 11:18 AM
This might be called a 'bodge' fix....
Completely degrease the fitting inside and out.
Use super glue to bond the cracked part almost instantly.
Build up the outside with layers of a tough sealant when dry.. I have been using Soudal T-Rex. Let it cure completely and it shold seal well. Just not sure for how long.
dannobee 09-27-2025 02:18 PM
An old spark plug boot works great.
Jeff Alton 09-27-2025 02:55 PM
Put some heat shrink over it and heat it until the heat shrink seals the crack.... double up the heat shrink if you want as well.
Done it a few times....
85RedCarrera 09-28-2025 04:09 PM
I’ll have to sift through my spark plug boots to see if I’ve got one that matches up.
The double fuel line idea sounds pretty stout. I could even put heat shrink over that.
I feel stupid now for removing the crimp- I could have repaired the tear easily using any one of, or a combination of these methods
I’m also liking the super glue + heat shrink idea. I could put a couple layers of heat shrink on it after.
Thank you for some great ideas.
SlateBlueTarga 09-29-2025 11:04 AM
I had the same problem a while back. I ended up going down to my local NAPA and picked up a piece of 15/32 brake servo hose. The hose was supple enough that a shot of WD-40 helped it stretch over the big end without much fuss. It looks like it belongs there and is holding up fine.
John
http://forums.pelicanparts.com/uploa...1759165969.jpg
85RedCarrera 09-29-2025 07:05 PM
John
Damn, that looks like it came straight from Germany...!
Flat6pac 09-30-2025 11:01 AM
Vacuum line
Straight from Germany and my Carrera stash
Bruce. Pm if interested
http://forums.pelicanparts.com/uploa...1759255151.jpg
john walker's workshop 10-03-2025 03:54 AM
Heat shrink works great.
PeteKz 10-03-2025 02:41 PM
^^ That's a great idea. I've used it to repair the arm on reading glasses too.
