missed using sealant - will it leak ?
When assembling the block I did not use any sealant on the two highlighted areas. Engine is only half way asembled and I am considering to take it apart again to add sealant to reduce risk of oil leak along the 8 mm stud and nut. What do you think ?
80SC (ex California)
Old 10-03-2025, 02:09 AM
I wouldn't worry about it. I like to use an aluminum washer on the lower stud, just in 1/1000th chance there is seepage.
206 637 4071
Old 10-03-2025, 03:49 AM
Just a personal trick, I remove that lower stud before mating the case halves and reinstall it later. Then you don't have to wiggle the right case half around until the stud aligns with the hole. Less chance of the chain and rods falling sideways, even with their supporting clips.
206 637 4071
Old 10-03-2025, 09:00 AM
PCA Member since 1988
As usual, John calls it. I might swab some sealer around the nut and washer. These are not under oil pressure.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 10-03-2025, 02:46 PM
John, I do like the idea. It would keep the intermediate shaft bearing from being knocked out of place which is always my worry.
Bruce
Old 10-03-2025, 06:58 PM
Makes mating the cases a snap. Start the two studs at the flywheel end and mate 'em. That stud always bugged me since forever, just started doing this recently, duh.
206 637 4071
Old 10-03-2025, 09:55 PM
Try not, Do or Do not
Henry Schmidt's Avatar
One caveat: as a rule, on mag cases, we always insert the four long stud holes around the front of the case during the case prep but if you skip this process you might find that the long intermediate bearing stud threads will often pull out when torqued.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-04-2025, 07:02 AM
Damn mag cases!
206 637 4071
Old 10-04-2025, 09:28 AM
Damn mag cases!
They're just like your kids. They aren't all, star athletes, scholars or rock stars but they're still family.
You identify their flaws and do your best to mitigate future failures.
Henry Schmidt
Ph: 760-728-3062
Old 10-04-2025, 09:59 AM
Good analogy.
206 637 4071
Old 10-04-2025, 11:20 AM
