Check valve
Should a '76 911 2.7 have a fuel check valve at the fuel pump outlet? Thanks!
I recall, the 76 has the pump in the left rear. The banjo that connects there is the check valve.
911 356 066 04 is the hose, the check valve is in the banjo next to the pump I have purchased the check valve by it self Bruce Last edited by Flat6pac; 11-17-2025 at 01:43 PM.. |
PCA Member since 1988
Same as above. Some pumps have a check valve on them, others use a separate check valve. Whichever, you should have a check valve somewhere between the pump and your CIS.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
yes, there are some in the banjo fitting depending on the year
chart notes pumps with the internal check valve with a (F) under outlet connection
