PCA Member since 1988
Silverlock: Remind me, do you have an AFR gauge installed? If so, what does it read at idle and other conditions/.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
I’m teeing up a fresh dyno run + AFR logging before end of season so I can have Steve Wong a) bring my redline up to 7.5k and b) see if there’s any “safe” power left on the table with the ignition map. Will post that + the logs when I get them.
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings) Dynamic CR calculator: https://dcr.questionable.services/ |
