nene's Avatar
Engine – Tick-Tick-Tick
Moving this thread over to this side for more visibility.
(The sound may be more of a Tap-Tap-Tap.)
My 86 Carrera has an annoying ticking sound for a while now and thought it was the valve lash which was not. Double confirmed adjustment and the tick was still there.
The sound generally is more noticeable when cold, but dissipates upon warming up, but it’s still there. At times when cold, the sound is almost non-existent. It appears to be on the passenger bank side.
To make a long story short, when I installed the RSR rocker shaft seals on all shafts, I noticed that the exhaust valve on cylinder five had a slight lateral movement which all others did not and were a tight fit. The engine has approximately 220k miles on the clock with a recent rebuild at some point which I don’t have documentation for, but just the word from the PO. Oil consumption is very low (1 quart per 2000k miles) or so.
When I replaced the engine bay fuel lines and remove the plenum, I noticed that the heads were Mr. Clean clean with very little residue which confirms a rebuild at some point.
I will be changing the oil and taking the exhaust rockers, shafts and springs to take another look.
Appreciate any and all advice.
Serge
Old 10-17-2025, 01:29 PM
Jeff Alton's Avatar
Can you post a video of the noise? Is it one bank, or both banks?
Also, if you can get a cheap stethoscope from local parts house, you should be able to determine which cylinder and which area the noise is coming from. Injector, intake valve, exhaust valve, piston or bottom end area.
Cheers
www.turn3autosport.com
Old 10-18-2025, 05:24 PM
nene's Avatar
Thanks for the response Jeff. I am checking the (exhaust) rockers/bushings and springs on the passenger banks. At this point, number 5 looks good and nothing broken.
Moving on to 4 and 6 as it appears to be coming from this side.
Old 10-20-2025, 09:15 AM
