Oil Pressure Switch @ triangle, just want to confirm
Since I'm finishing up my first Porsche engine rebuild, I'm driving myself a little crazy wondering if I had forgotten anything.
I circled the parts I had a question about below.
When I took it apart, I don't remember a check ball or anything like the photo. It was just the oil pressure switch, the mount (like #42) and a crush washer under it.
Am I correct to think that?
Is the small assembly with the check ball for a different model?
There is a long passage under the oil pressure switch which leads straight down to the oil pressure relief valve.
Old 12-15-2025, 05:23 PM
Jeff Alton's Avatar
Your parts diagram shows parts that are on a 930 Turbo, not a NA car. Your pic looks correct.
Cheers
www.turn3autosport.com
Old 12-15-2025, 06:18 PM
Cheers
I owe you not one but at least TWO beers now, Mr. Jeff Alton! Thank you.
Old 12-15-2025, 06:41 PM
Jeff Alton's Avatar
All good, the diagrams can be confusing at times..... We deal with this sort of thing everyday and it takes no time to reply and offer answers!
Keep up the good work!
Cheers
Old 12-16-2025, 09:47 PM
