Banned
new rings
hey
I have a set of rings(Deves) that I had sitting for sometime , I was going to use them for my rebuild, Is it a good Idea to let the rings soak in oil for a few hours or overnite before installing them?
thanks
Dave
Old 07-14-2003, 07:40 PM
PRO Motorsports
Tyson Schmidt's Avatar
Not necessary. Some Pro engine builders install the rings dry! (to help them seat initially) I believe the Factory uses a very light coat of ATF.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 07-16-2003, 09:29 PM
Banned
I installed/mearsured the rings last night,
I soked them for a few hours, wiped clean, and wiped out the cylinder with a slightly oil damp papertowel, ,
the bottom ring (oil one) was the tightest one to slide in, and with these new pistons the oil ring is down by the skirt?? now I need to get another kind of piston ring compressor to put the P/C on to the block, because to get the wrist pin to slide onto the rod the oil ring needs to be out and uncompressed.
FUN
Old 07-17-2003, 06:02 PM
