Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
latest on 3.0
Got my cylinders installed last night.
Spent a few evenings cleaning up the pistons. Soaked them in PB blaster, then the carbon scraped right off. Used a scotch brite pad to finish them off. They were just black before.
On to the heads!
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 07-03-2003, 04:57 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
Lookin' good john, Can't wait to see the 912-6 on the road.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 07-03-2003, 05:48 AM
MY83SC's Avatar
WOW! Can't wait to do my 3.0! Great job....Please keep the Pic's coming!
Mike
83 SC
Old 07-21-2003, 06:38 PM
smestas's Avatar
Send a message via AIM to smestas Send a message via Yahoo to smestas
John,
I just noticed from your images that you dont have your ground wire for the alternator on.
Just thought I should mention it.
Simon Mestas
'78SC Coupe
My Pelican Page | AlfaBB - Alfa Romeo Forum
Old 07-21-2003, 11:24 PM
Stahlwerks.com
jhelgesen's Avatar
Hadn't forgotten it. I had it off while I was making a duplicate to repair a customers car.
thanks for the heads up though.
John Helgesen
Old 07-22-2003, 04:44 AM
rw7810's Avatar
John - Which technique did you use? pistons on first, then cylinders or insert pistons in cylinders and then on rods??
Robert Williams
70' 911T
Old 07-22-2003, 11:10 AM
Stahlwerks.com
jhelgesen's Avatar
Since these are used pistons and cylinders, I cleaned the carbon off the pistons, installed them in the cylinders, then onto the rods.
John Helgesen
Old 07-22-2003, 01:14 PM
dtw dtw is offline
GAFB
Hey John,
Where did you find those handy cylinder retainers? I need a set of 'em. Did you have any trouble with the through-bolt seals? I've heard those are fiddly.
Several BMWs
Old 07-23-2003, 11:17 AM
Stahlwerks.com
jhelgesen's Avatar
The cylinder retainers are available at your local Sears store, 1/2" drive, standard depth sockets and 10mm nuts.
The through bolt seals weren't bad, just followed Waynes instructions in the book, a little sealant, the o ring, a little more sealant, then install. Far as I know so far, they are sealed well.
John Helgesen
Old 07-23-2003, 11:36 AM
Halm's Avatar
Very nice job! And as MY83SC said, "keep the pictures coming".
'17 Cayenne
Old 08-02-2003, 06:28 AM
Stahlwerks.com
jhelgesen's Avatar
Thanks guys, I'm almost done painting the cylinder tin, so I'll be back to work on it this week.
John Helgesen
Old 08-02-2003, 07:05 AM
