2,2 piston/cylinder question
Wayne,
I have my engine (2,2) down to the connecting rods. I read in your book about keeping the wrist pins with the same pistons. That makes sense but you also mentioned mix and matching them with pistons to do a little low budget balancing. Were you talking about new parts or the old parts? The fact that the wrist pins have already been pressed in would make be think that they should stay with the same pistons. But then given the superior German engineering that was put into these engines make me think the tolerances would be quite tight. Cast iron cylinders- besides honing them what else do you suggest? The cross-hatching is till visible with very little carbon build up. Mike
Thanks, Mike When I was a kid, I didn't want a stupid pony, I wanted a PORSCHE. 1970 911T Coupe, 1979 911SC Targa Euro, 1971 Honda CT70 HK Trail 70 (the ultimate in two wheeled transportation) |
Author of "101 Projects"
Uhh, you're confusing things. You should make sure that your piston pins are kept with the proper pistons *after* they have been balanced together. Beforehand, it doesn't really matter.
Have the cylinders checked for ovality with a dial bore gauge... -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Re: 2,2 piston/cylinder question
-Wayne
