Engine Rebuild Book Question
Wanye,
you included the dimensions to make the rod and chain holders used in the case assembly. I just can find the width of the parts anywhere? What is this dimension?
Thanks,
Arnie
Old 08-22-2003, 08:38 AM
dtw dtw is offline
GAFB
Width is not a critical dimension. Just measure the width of your rods and timing chains and approximate that with your holding tools...
Several BMWs
Old 08-22-2003, 10:16 AM
I made mine with a piece of the tin c-clamp that holds the joints of heating duct together. It's about 1" wide. I couldn't bend it to exactly the shape of the pictures but it worked great. Once the case was together I took my tin snips and cut them up. In the can they went.
I used this because it was there. I'm sure you can get it at any home center for a few bucks. I think I used about 4-6 feet. (At the most.)
Bill Miller
81 Targa Guards Red
3.6, M&K 1 out, S4 brakes
83 ROW CAB Rubinrot Metallic (RIP)
Old 08-22-2003, 01:47 PM
Super Moderator
cstreit's Avatar
Made mine out of some hardware store aluminum... like 3/4" width, bent by hand... Easy-peezy
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 08-23-2003, 02:51 PM
