It'll be legen-waitforit
stealthn's Avatar
Cam repair
What options do I have with my SC cams that appear to have some pitting on the exhaust side (only one cam). I think it was caused by moisture on them, but not sure.
Money IS an object as we found them when the car was in getting a bunch of other work done.
Thanks in advance,
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 08-18-2003, 09:49 PM
350HP930's Avatar
A regrind may remove all the material in question.
Old 08-18-2003, 10:00 PM
Irrationally exuberant
ChrisBennet's Avatar
Re: Cam repair
Thanks in advance,
I'm curious, are you using Mobil 1?
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 08-19-2003, 06:31 AM
stealthn's Avatar
Chris,
No; Castrol GTX, I always have (after talking to two mechanics), but I can't say for the PO.
By the looks of the oxidization/corrosion I would think the Cam would have had to be sitting for quite a while with moisture on it.
I hope it wasn't me and these Canadian garage winters.
It's being taken out and sent to a shop for a quote to weld/grind. Collective finger cross here X
Bob James
18 Macan GTS
Old 08-20-2003, 09:03 PM
stealthn's Avatar
Is it worth considering the 964 re-profile? or others?
Thanks in advance,
Bob James
18 Macan GTS
Old 08-24-2003, 09:52 PM
