| Registered |
				Where can I get 3.4 litre pistons for 3.2?
			I have looked everywhere to find the 100mm piston and cylinder kits to upgrade my 3.2 careera. Any ideas?
|  08-27-2003, 08:28 PM |
| Author of "101 Projects" |
			We can special order them, but they are not cheap.  They typically run about $3600.  Give Tom a call at 1-888-280-7799x221. -Wayne
				__________________ Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports | ||
|  08-27-2003, 09:15 PM |
| Hilbilly Deluxe |
			3.4L pistons for a 3.2 Carrera are 98mm. Tom | ||
|  08-27-2003, 09:42 PM |
| Registered |
			Thanks !
				__________________ 87 Carerra Coupe 04 GMC Yukon 07 Mazda 3 00 GMC Sierra | ||
|  08-28-2003, 03:29 AM |
| Registered Join Date: Jul 2001 Location: Portland Oregon
			Toolman: Just a further application note here for your Carrera,.... 98mm P/C's make 3.4 litres and no case machining necessary. Its a slip in. 100mm P/C's make 3.5 litres and the case spigots must be enlarged. A 3.5 makes really big power,....  Other mods should be done to take full advantage of the displacement change.
				__________________ Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com Last edited by Steve@Rennsport; 08-28-2003 at 09:12 AM.. | ||
|  08-28-2003, 09:09 AM |
			Right-o.  Implying from Toolman's post, I think he wants the plug-in 98mm ones from Mahle, which are easier to find than the 100mm ones... -Wayne
|  08-28-2003, 01:14 PM |
| Registered |
			Yes, easier=better on this project. I will be tearing into this top end rebuild in about 2 weeks. I was just looking at all my options. It looks like pistons and cylinders are going up so I hope mine are OK.
|  08-28-2003, 06:51 PM |
			You can also have yours bored (see other thread), and run JEs at 98mm for a cheaper option.  Or, sell off your pistons and cylinders as a set, and buy a set of 95s to be bored out (like the ones I have on eBay right now)... -Wayne
|  08-29-2003, 03:08 AM |
| Registered Join Date: Jan 2003 Location: Langley,B.C.
			Wayne, are you saying I can have my 3.2 cylinders bored out to 98mm and get a set of JE pistons and I am set?  Who does the boring and what are a set of pistons worth(ballpark)? Jeff
				__________________ Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 | ||
|  08-31-2003, 02:25 PM |
| Registered |
			I called J&E. Pistons-complete at 9.5 to 1 were about $950. Bore and Replate cylinders at US Chrome in fond du lac, wisconsin about $175 each.
|  08-31-2003, 04:29 PM |
			Thanks for the info. That is great! Cheers, Jeff
|  09-01-2003, 04:34 AM |
