LinkBack Thread Tools Rating: Thread Rating: 1 votes, 4.00 average.
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
rocker arm refresh?
I'm upgrading my T engine to E specs. I've located a set of good used E cams (no pitting) but the rockers were broken on it so I can't get the rocker arms that should go with this cam. I have a set of good rockers off my T cams but I think they'll need machining at the least. I looked at webcams website and they want $65.00 per arm to hardweld them and pelican has new arms for $31.00 per arm. What is the recommended procedure to make these rockers and camshafts ready for another 100K miles?
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 09-19-2003, 07:34 AM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
Tim,
Another option is to send the rockers to CE for rebushing and refacing. Cheaper than buying new rockers. With the fresh rockers, just make sure you run the 20min @ 2K break-in to mate them with the cams.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 09-19-2003, 08:40 AM
Tim Walsh's Avatar
AHH ok I'll definitly have to do that. I'm pretty sure my machinist can do that since he's a local porsche only raceshop and even if he can't I'm sure that rebushing the rockers is cheaper than new ones ($400 for the set)
Edit: If I was smart I would have looked in my rebuild book... $20 per arm at CE makes it about $250. Much better than $400 for arms + extra for the shafts
Tim
1973 911T
2005 VW GTI
Old 09-19-2003, 08:51 AM
New rockers and cam lobes need adequate lube for breakin. There are special lubes for this purpose.
Sherwood Lee
http://members.rennlist.org/911pcars
Old 09-19-2003, 12:20 PM
Tim Walsh's Avatar
Sherwood,
What is the recommended lube for this? I assume the ussual moly lube isn't enough
Tim
1973 911T
2005 VW GTI
Old 09-19-2003, 12:38 PM
Moly (extreme pressure lube) is good for this. You can also add GM's EOS (Engine Oil Supplement) to the oil supply. Others may want to chime in with their preferences.
Sherwood
Old 09-19-2003, 12:48 PM
Senior Member
Doug Zielke's Avatar
Originally posted by kstylianos
Tim,
Exactly what I did.
Walt did a fantastic job, for a very reasonable charge.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 09-19-2003, 07:04 PM
Originally posted by Doug Zielke
Exactly what I did.
ditto
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-20-2003, 09:26 AM
