Picked up a 1982 3.0 SC with 106K miles and the engine partially disasembled by a non porsche mechanic. Need some advice:
Do I really need to tear it all the way down, send out to a machine shop in California to check tolerances, and then rebuild? Or can I utilize a local machine shop to check the cranks for cracks, clean everything, have the heads redone, then put it all back together. The engine was smoking when they pulled it apart. The cylinders look excellent and the pistons look like they should according to Wayne's book. Only thing I know is that they overfilled the oil resevoir which could have been the major cause of the smoking. Also know that the guy that owned it probably drove it hard but did replace things when they had problems. Although, his solution was typically to throw money at it. Anyone else's thoughts? Do I have to spend the big money at the machine shop or not? |
Since the engine is out of the car and is partially torn down, you should AT LEAST replace the bottom Dilivar head studs if this has not been done yet. To get to these, the P/C's need to come off. Depending on the type of cylinders you have, you'll have a few questions to ask yourself.
If Alusil: Should I remove the pistons from the cylinders to get them measured and risk new rings breaking in. Should I reuse the same rings? If Nikasil: No brainer, remove the P's from the C's and at least get them measured and diamond honed if needed. No ring seating issues here if properly honed. How much farther down you want tear down from here is up to you. Since you only have 106K on the engine, the bottom end *should* be in decent shape if properly maintained. The condition of the rod bearings will give you an idea. You can remove the rods w/o splitting the case. Refreshing the bearings is cheap ($60) and don't forget new rod bolts.
Charlie Stylianos 1982 SC Targa www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles) |
and Competion Engineering in Calif is my favorite. IMO, CE is a no-brainer......Ron
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
The are Alusil. So, does that mean I'm hosed (new pistons and cylinders)?
I think I've made the decision to break the case and at the very least, clean it up. I figure while I'm there, I'll replace the bearings and what not. Motor Meister has a great Marketing ploy about how they can do a lot of the machine work. But then, I've heard some negatives about them. Along with some positives. So, I'm really not sure on that. Went to a local machine shop and ruled that out. So, what are your thoughts? I would like to keep the rebuild under $3000 but can go up to $4000. I plan on doing the assembly myself, just need the machine shop portion. |
I think that if your pistons and cyls are in spec, especially the top ring land, it's doable......Ron
I'm glad to hear that. The cylinders look to be perfect but I haven't had them calibrated yet. That will be the big question.
Thanks for the advice. Since I'm new at this, I can't seem to get enough right now. |
If you really want to keep those ausil's, i can give you a contact to a shop in jersey that has the ability to lapp the cylinders for reseating.
2007 Mazda 3 hatch 1972 Porsche 914 roller with plenty of holes to fix
Would love a recommedation.
Quick question? How do I know if I need to do anything to them. Do I need to have them measured for tolerances or is it more than that? |
Author of "101 Projects"
You don't have to necessarily send it to CA - just make sure you use a shop that works on Porsche 911 engines often. As you read in the book, there are lots of little nuances that are unique (and important) to the 911 air-cooled engine...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Super Moderator
The good news is that a 3.0L case generally does not require much in the way of machining, but if you plan on keeping this car for a good amount of time, you might as well. Better to go with an established shop and send it out only because the consequences for failure are high and, even though these guys tend to be slower, you need not be worried. Peace of mind is worth a lot.
Drive it like u stole it.
As far as a recomendation for a machine shop I would like to put my 2 cents in. I had all of my machine work done by Ollies in Santa Ana, CA. They did nice work and had a resonable turn around time. There prices are in line with most shops and they are easy to deal with. From what i understand Andial uses them often as they are the ones that suggested them to me. Give them a call and they will fax you there price list.
Ollie's Automotive Machining 510 Terminal St, Santa Ana, CA 92701 Phone: (714) 558-7334 tell them Bill Jones from Jupiter sent ya. |
