Nathan M's Avatar
Head reface question
What's the max amount which can be taken off the cylinder heads on a 3.2 without running into clearance problems (or any problems!) and how much of a compression ratio increase can I get by doing this? (or is it a stupid question!?!?)
3.2 Coupe
Old 09-11-2003, 06:16 AM
Nathan M's Avatar
any takers?
3.2 Coupe
Old 09-17-2003, 05:49 AM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
Natahn,
If you provide me your e-mail, I can send you a compression ratio spread sheet. Send me a PM.
You'll need to know your current bore, stroke, head and piston dome volumes, assume a deck height of 1.25mm unless you know what it actually is. You can play around with the numbers and see what changes in head volume (CC) can do to CR. I don't know exactly how much milling will reduce head volume CC....a machine shop can probably figure it out if you provide them the CC's.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 09-17-2003, 07:31 AM
Author of "101 Projects"
Wayne 962's Avatar
In general, it's not wise to flycut your heads to increase compression ratio - at least on a 911 engine. The best way is to use JE pistons, or to stretch the rods. These methods are a bit less destructive to your engine. Once you flycut - that's it -they're done...
-Wayne
Old 09-17-2003, 01:55 PM
