Clubsport valves ?
I've opened up a 3.0L of mine that's supposed to have had Clubsport intake valves installed during its last rebuild. Anyone know of a way to verify that? The valves have KTRWT30184/116 on their stems. Is that the same part number of the normal 49mm intake valves?
Thanks,
Rob
1980sc
Old 09-08-2003, 08:32 PM
Irrationally exuberant
ChrisBennet's Avatar
Do you have a way to weigh the valves? The Club Sport valves would be lighter than stock. I can weigh a few stock valves for you if that would help.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 09-09-2003, 05:32 AM
I doubt I could come up with a scale accurate enough.
If you, or someone else, has a stock intake valve around, could you look for a TRW number on the stem near the top?
Thanks,
Rob
Old 09-09-2003, 07:23 AM
I can look this weekend.
-Chris
Old 09-09-2003, 07:36 AM
OK, I looked at a 3.2 intake valve. This is what was written on it:
T-T 307013
930 105 409 13
The in the first number, the "T-T" looks like a "TT" that had the first "T" over typed with an "F". Maybe "T-T" it's a stylized "FT"?
The 2nd number is proceded by the triangular Porsche trademark sign.
-Chris
Old 09-10-2003, 11:41 AM
Thank you for looking. My intake valves do not have a Porsche part# on them. Just KTRWT30184/116.
I tried searching the TRW website for part numbers, but had no luck.
Thanks,
Rob
1980sc
Old 09-11-2003, 01:50 PM
I weighed one of my mystery intake valves on a postal scale today. It said the weight was 4.0oz. Can't be sure how accurate that is though...
Still want to weigh that intake valve of yours Chris?
Thanks,
Rob
1980sc
Old 09-16-2003, 07:54 PM
I'll try to weigh one.
-Chris
Old 09-16-2003, 10:52 PM
Nathan M's Avatar
TRW ref 30184 is a standard Carrera inlet valve, OE ref 930.105.409.14
The equivalent exh. valve is TRW ref 3051 (930.105.419.08)
Nathan
3.2 Coupe
Old 09-17-2003, 05:46 AM
Not that it matters now but I just weighed one. I removed the carbon but there is still a little bit on it. A Carrera intake valve weighs 3.8oz.
-Chris
Old 09-17-2003, 05:53 AM
Thanks so much guys !
I had a feeling these were the "normal" valves. I keep finding things on this engine's rebuild receipt that are simply lies...
Rob
1980sc
Old 09-17-2003, 07:02 AM
