-   -   Cam ID (http://forums.pelicanparts.com/911-engine-rebuilding-forum/129029-cam-id.html)
69 911s 09-25-2003 02:19 PM
Cam ID
Can anyone ID these cams: 90110510402 and 90110510302
Thanks, Holder Trumbo
jluetjen 09-25-2003 02:28 PM
I tried looking them up and couldn't find them listed in the Spec book. The factory shop manuals didn't have anything either. Maybe Warren (Early S Man) knows...
jgparker 09-25-2003 04:45 PM
The base number is off a carrera 6 or a 911 R cam, but the 02 suffix must be a special grind. Could it be an early 911 factory racing cam?
69 911s 09-25-2003 08:47 PM
Funny you should ask. The seller says that the right cam has the MFI drive attachment area, but that should be on the left cam. Also it has three holes instead of the four that a MFI extension should have, much like the tach cable attachment that is pictured in Bruce Anderson's book and described as being "on early 901-derived racing engines", (p88. second edition) So what are they? Also, they are center oilers.
Interesting...
Wayne 962 09-25-2003 09:09 PM
Probably very early 901 cams - you need to have them profiled to accurately determine what they really are...
-Wayne
69 911s 09-25-2003 09:13 PM
We can't tell what they started life as from the numbers? I'm curious from a research point of view.
Thanks.
Tim Walsh 09-26-2003 05:32 AM
They may have started out life as cams from a race car but they could have easily been reground to a different profile. It would then have the same #'s but a different profile. That's why a cam doctor is so nice. There's rutimentery ways of checking the profile as well. Check the archives.
69 911s 09-26-2003 10:10 AM
Tim,
I absolutely know that they could be any profile, and I will check them out when I have them in hand, but my question comes from the 911 historian in me. I'm interested, as you know, in early high performance 2.0 engines, and frankly would possibly have these put back to original profiles if possible, especially if it was a racing cam, but I'd like to know what that was.
Holder
Tim Walsh 09-26-2003 11:09 AM
ahh ok. I should have read better. I think it's very cool that you've got old racing cams in your engine.
69 911s 09-26-2003 11:13 AM
Don't have 'em yet, but I might attach them to a certain 69S block, if you know what I mean...
