Deviant
Hello,
Well I had the chance to drop my motor yesterday in my '82 SC. I used Wayne's 101 Projects book and it was very helpful . I decided to pull the motor and transmission together because they have 154,000 miles on them. I thought it would be a good idea to rebuild both. Two things could have gone better: 1. The shifting linkage shaft got hung up for a few minutes. Will there be any damage from this? Everything appears fine from the outside. I had no idea how long it was when I was pulling back. 2. The motor leaned over a little while I was yanking it out from under the car and the throttle linkage sheared off at the case. I think that I can use an extractor and get the bolt out. Is that a dealer part or a bone yard part? Thanks
Tim Looney '82 911 SC - sold.... |
The shift shaft that pokes out of the end of the 915 is a pretty strong piece of steel. I doubt you may have bent it.
As for the throttle linkage bolt that sheared, I'm not sure what you are referring to. There are a couple of studs that mount the throttle pivot on top of the backside of the motor underneath the CIS, but I don't see how you could've sheared that off without damaging a lot of other stuff. If you were referring to the bell crank on the 915, there are no bolts there. The pivot shaft is pressed into the case and a cotter pin holds the crank in place.
Eugene (Formerly) at Pelican Parts Pelican's E-Commerce Guy, 2003-2011 2001 330i Sport 1983 911SC Coupe (sold) |
the trans pivot shaft threads into the case.
