Flywheel/Pilot bearing issue
What combination of flywheel and pilot bearing will work on a 3.2l Carrera Engine that has a 3.3 turbo crank and is being mated to a g-50 transmission? I would like to retain my current clutch and pressure plate.
I apologize for the repeat, but with a bit more info, I believe I have a better problem description.
Thanks,
Arnie
Old 10-02-2003, 11:50 AM
