Pilot Bearing for an '87 3.2l w/ 3.3 turbo Crank
I am in process of rebuilding my 3.2 l and because of the spun bearing I had to replace the crank. The only crank I could find was from a 3.3 Turbo. I went to install the Pilot bearing today and realized I had the wrong part and also found that the correct parts bolts on to the end of the crank (per Bentley) w/ 3 bolts. My crank only has one taped hole. The question is, how much trouble am I in? Can this be repaired short of finding a new crank and tearing down the entire engine? Help....
Thanks, Arnie |
Author of "101 Projects"
Can you post a pic?
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
No Camera
Wanye,
Sorry, I don't have a digital camera. From the Bentley manual (in the clutch section) there is a photo of the Crank/flywheel mounting flange. This shows the 9 holes for the flywheel and a set of three holes on a smaller bolt circle for mounting the pilot bearing. My new crank has only only one hole in this general location. I don't remember taking this bearing off when I disassembled the engine and it went to Comp Engineering with the flywheel for balancing. I was wondering if you had any pictures of the 87-89 pilot bearing. I looked at your website, but no picture existed. Thanks, Arnie |
Your 1987 has the G50 transmission, which doesn't use the same pilot bearing as the earlier cars which used the 915 transmission. Your pilot bearing is pressed into the flywheel - not bolted to the crank. So the pilot bearing for your car (931.102.111.00) should work with this crank.
The Bentley book is probably incorrect in this area... -Wayne
Wanye,
Thanks for the research. I had other similar inputs. Thanks, Arnie |
