What are cylinders worth as core
I have a set of 3.2 cylinders and want to know what they are worth as a core for re-boring and replating as a larger size such as a 98mm.
Old 10-09-2003, 06:00 PM
Hilbilly Deluxe
emcon5's Avatar
I don't knowfor how much, but EBS buys them.
I need 3.2 cylinders nickasil or alusil 95mm
82 911SC Coupe
GTI Cup #43
Old 10-09-2003, 08:13 PM
Hilbilly Deluxe
emcon5's Avatar
While both are 95mm, I thought the 3.0 cylinders had a groove for a sealing ring, and the 3.2 didn't.
As I understand it, the 3.2 cylinders can be bored out to 98mm, but the 3.0 jugs can't.
Is this right Wayne?
Tom
82 911SC Coupe
GTI Cup #43
Old 10-09-2003, 10:27 PM
Author of "101 Projects"
Wayne 962's Avatar
They are the same cylinders, basically. Right - I think that there may be a slightly different mounting ring on the top (no gasket), but I can't recall, and I don't have any sets here. Either way, they are still interchangeable.
Functionally, there isn't any difference between the cylinders, so there is no logical reason why you would be able to bore one and not the other. The difference between the 3.0 and 3.2 long block lies in the stroke length - no piston / cylinder enlargement...
-Wayne
Old 10-09-2003, 11:46 PM
Irrationally exuberant
ChrisBennet's Avatar
EBS won't use the 3.0 cylinders as cores for making 98mm cylinders because of the head gasket groove.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 10-10-2003, 08:49 AM
Stressed Member
Scott Clarke's Avatar
EBS's core charge for cylinders is $300, or at least it is for 90mm cylinders.
'70 911E short stroke 2.5 MFI. Sold
'56 Cliff May Prefab
Old 10-10-2003, 12:18 PM
