How much of a BAD IDEA is it to use a LOW impact set-up on those cam nuts..???? Frank
Now in 993 land ...
I would not use an impact on anyhing but he flywheel bolts. Air ratchet to take bolts off, fine, but an impact on a piece that is 80% aluminum and / or magnesium?
I suppose you have trouble with a breaker bar only? How are you going to hold the cam while applying that impact? I might miss something here? What year engine are you working on? Cheers, George |
GAFB
I have always used an impact wrench to remove cam nuts on engine teardown; they spin right off. If you are reassembling the motor and removing the cam nuts during your timing setup, then I'd think that is probably a bad idea. Take the time to set up a flywheel lock. The cam nuts come off fine with a flywheel lock and breaker bar.
Several BMWs |
Irrationally exuberant
I use an impact wrench on cam nuts and bolts all the time. Obviously, it works great for disassembly but it's also nice for removing/installing them when you are timing the cams. When tightening/torquing the big cam nuts by hand, I like to have a helper. (One to hold the crows foot and breaker bar on the nut and one to hold the torque wrench.) The impact wrench lets me do the cam timing by myself and then grab a helper for the final torquing.
Before I owned one, I thought of an impact wrench as a butchers tool. Now I realize, that yes, butchers use them but it's not the tool that's bad. BTW: Dave mentions removing the cam nuts by using a a flywheel lock to hold the crank. This is probably OK if you are replacing the chain but I wouldn't want to do this otherwise. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
I am working on a 81 3.0 that has the Nut...Thanks Guys Frank
The chain links take the brunt of the force when you use an impact wrench. Question is, is there any long term harm to the chain using sudden torque (approx. 200+ ft. lbs) from an impact wrench?
Sherwood Lee http://members.rennlist.org/911pcars |
Warren Hall Student
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
I question whether the impact wrench really does put much force on the chain
I question whether the impact wrench really does put much force on the chain. In the case of the big cam nut, it probably does yank on the chain some if you don't counter hold with the cam wrench. You can see the chain vibrate when you do it. I can't remember if I counter hold the (early) cams or not. Now that you've made me think about it I will be sure to. In the case of the later style cams ('83-?) I think impacting the cam bolt tugs on the chain very little if at all. An impact wrench uses lots of little "rabbit punches" that are so fast that the inertia of the cam isn't overcome i.e. you don't even need to hold the later style (bolt) cam. This became evident to me once when I was timing cams a few years ago, With the cam set up for timing and the dial indicator reading around 1.25mm, impacting the cam bolt changed the reading by .02mm. For those of you who haven't timed cams before, you only need to breath on the cam to change the value by that much or more. -Chris
Author of "101 Projects"
Impact wrench should be okay for removal *only*...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Yes,..The impact wrench worked great,..did'nt even stress the chains at all...Frank
Re: I question whether the impact wrench really does put much force on the chain
-Wayne
Re: Re: I question whether the impact wrench really does put much force on the chain
-Chris
Chris,
While you may have the expertise to only torque to a certain amount, I can imagine many others who think that a 'blurp' is longer than you would think. While probably okay for expert mechanics (like yourself), I really wouldn't recommend this for the average joe... -Wayne
