No Expert
Weber 40 IDA set-ups
I'm looking for recommendations on my Weber set-up. My new engine is a 2.8, J&E pistons 9.5:1, early S-cams, 35mm intake and 36mm exhaust ports, SSI and dual-out exhaust, single ignition and RS distributor. Also, I'm at sea level, and the car is mostly used on the track. This is what I think I need:
Venturies: 36mm Main Jets: 160 Idle Jets: 60 Air Correction Jets: 180 Emulsion Tubes: F3 Is this reasonable? Also, where should I get these parts? Thanks, JP
-- Last Engine rebuild project, Now a coffee table. -- New engine rebuild project, Alive and well. -- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S |
A lot of Webber Parts are available through PMO and Eurometrix.
'17 Cayenne |
that setup should get you started ok.
Author of "101 Projects"
Right - looks like a good starter. The expert is Richard Parr at PMO (also Steve Weiner is good at these setups, I hear from his customers)...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
