No Expert
jgparker's Avatar
Weber 40 IDA set-ups
I'm looking for recommendations on my Weber set-up. My new engine is a 2.8, J&E pistons 9.5:1, early S-cams, 35mm intake and 36mm exhaust ports, SSI and dual-out exhaust, single ignition and RS distributor. Also, I'm at sea level, and the car is mostly used on the track. This is what I think I need:
Venturies: 36mm
Main Jets: 160
Idle Jets: 60
Air Correction Jets: 180
Emulsion Tubes: F3
Is this reasonable? Also, where should I get these parts?
Thanks,
JP
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 10-17-2003, 04:52 PM
Halm's Avatar
A lot of Webber Parts are available through PMO and Eurometrix.
'17 Cayenne
Old 10-17-2003, 05:04 PM
that setup should get you started ok.
206 637 4071
Old 10-17-2003, 06:58 PM
