-   -   Cant get Rocker arms Loose (http://forums.pelicanparts.com/911-engine-rebuilding-forum/132213-cant-get-rocker-arms-loose.html)
flmont 10-19-2003 02:30 PM
Man...I cant get those rocker arms to loosen up at ALL..why are they so tight ...Frank
john walker's workshop 10-19-2003 02:49 PM
push harder, they gotta give. make sure the 5mm allen socket is fresh and true, and not rounded off, of you can round the rocker bolt off. you are using a 1/4" drive 5mm allen socket and ratchet, right? it would be hard with just an allen wrench.
Rot 911 10-19-2003 03:31 PM
Soak them down in PB blaster for at least overnight before you try to loosen them up. They are probably really rusted. Mine were. I just took mine out yesterday. Here is my thread on my experience: http://forums.pelicanparts.com/porsche-911-technical-forum/132094-engine-tear-down-disaster-narrowly-averted.html
Wayne 962 10-20-2003 02:43 AM
Right - some penetrant overnight (really - let it sit overnight) should help things a bit...
-Wayne
Jay Auskin 10-20-2003 02:28 PM
Don't forget to wear some substantial cotton gloves. This is a job likely resulting in skin being removed from your hands/knuckles when something slips!
rcwaldo 10-20-2003 06:14 PM
try a small butane torch and heat up the nut. The small butane torch wont likely get it VERY hot, but hot enough to expand it some and hopefully aid the removal...
Chris
