Man...I cant get those rocker arms to loosen up at ALL..why are they so tight ...Frank
push harder, they gotta give. make sure the 5mm allen socket is fresh and true, and not rounded off, of you can round the rocker bolt off. you are using a 1/4" drive 5mm allen socket and ratchet, right? it would be hard with just an allen wrench.
Friend of Warren
Soak them down in PB blaster for at least overnight before you try to loosen them up. They are probably really rusted. Mine were. I just took mine out yesterday. Here is my thread on my experience: Engine Tear Down: Disaster Narrowly Averted
Kurt V No more Porsches, but a revolving number of motorcycles. |
Author of "101 Projects"
Right - some penetrant overnight (really - let it sit overnight) should help things a bit...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
fancytown
Don't forget to wear some substantial cotton gloves. This is a job likely resulting in skin being removed from your hands/knuckles when something slips!
all cars sold. |
try a small butane torch and heat up the nut. The small butane torch wont likely get it VERY hot, but hot enough to expand it some and hopefully aid the removal...
Chris |
