Friend of Warren
HELP! I Dropped a Piston!!!!
Don't ask me how. I already feel incredibly stupid. Not to mention sick to my stomach. I dropped one of my pistons on the concrete garage floor and of course it hit on the weakest spot, the piston skirt. As you can see from the pictures I have a crack all the way through the skirt and the corner of the skirt is bent. The question is what are my options? Can I buy just a single piston or do I have to buy a piston and cylinder together. Damn! Damn! Damn my stupidity! I am cross posting this to the Tech and Engine Rebuild Boards to get as many good opinions as possible.
Kurt V No more Porsches, but a revolving number of motorcycles. |
PRO Motorsports
Well, that's obviously a used piston, so if I were you I'd look for another used piston from a dismantler, or private party. Measure the ring lands and determine what thickness the rings are so can find a matching piston.
Then, once you find a matching piston, get a gram scale and slide the wrist pins in each of the pistons. Then weigh them all, and if you find a heavy one, remove material from the wrist pin until they all match perfectly.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Friend of Warren
Tyson, thanks for the advice. But I have a couple of questions. First why would I need to measure the ring lands? Aren't all U.S. 3.2 pistons the same? Second, I like the idea of having all pistons weighing the same. Where would I remove the material from the wrist pin? I am assuming from inside the hole that runs through the pin, but I know what happends when I assume.
PRO Motorsports
You should remove material from the inside bore of the wrist pin until it matches. Preferably from both ends equally. I had to replace one piston during my rebuild, and the one I found was quite a bit heavier than the others. Even with the lightest wrist pin installed in it, I had to grind down the wrist pin quite a bit. It sure is a smooth running engine now. Those little attentions to detail make all the difference. Particularly on an engine like mine that spends quite a bit of time over 7000 rpm.
Author of "101 Projects"
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
i probably have a used one.
