I am installing the chain tensioner upgrade as I am putting my 71E 2.2 engine back together. How do I finish out the right side
oil line at the case?? I ordered the hose mod for the early engine but it came open ended on the case end and no instructions. HELP!!! cosmo
typical. you need to order the ferrule (crush ring), and use the nut from the old line. cut the line with a hacksaw to save the nut. i don't know why they sell the line with no hardware. useless.
Does the line end in a metal tube and if it was finished with a ferrule and nut would it be long enough? If yes to both then you likely only need a new nut and ferrule; Pelican Part Numbers: N-020-825-1 and I-104-003-02. See:
http://www.pelicanparts.com/catalog/shopcart/911E/por_911E_oilsys_main.htm Cheers, Jim |
Thanks John!
I too would like to know wht they sell it this way?? Wayne please explain
04 996 TT 71 911E 73 911S Targa 61 356 Coupe 69 XKE OTS 68 XKE Coupe 65 Healey BH8 |
Very frustrating! I had to search low and high one afternoon to find the proper metric ferrule...........finally found one at a truck fuel injection place.
72 Porsche 911T/E Targa 72 Porsche 911S 85 BMW 735i |
Author of "101 Projects"
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Wayne,
Why do you sell them without the nut and ferrule and no instructions??Their useless!!
GAFB
Wanna know what's even worse? Then you actually GET the ferrule and you end up with one that's a few mm too long. Then the nut can't quite make it to the case adapter. But YOU didn't know you had the wrong ferrule, so you just keep trying various ghetto methods of trying to make it work, until you end up destroying another thirty bucks worth of parts.
It'd be nice if PP could inspect their receipts of these lines, and drop a ferrule and nut into the bag if they are lacking. This issue cost me hours and $$$.
Several BMWs |
I will look into this issue. In general, my warehouse workers don't have the knowledge or experience to figure out that the parts have changed from our supplier.
-Wayne
Ok, put these instructions with each order on a pre 74 car.
Use the original left side new hose(it comes with the kit) and cut with a hacksaw just above the nut, remove the nut and drive off the ferrule. Install the nut and ferrule on the hose mod. and install. This worked for me.
GAFB
I'm not sure that ferrule is a multiple-use affair. It bites the line the first time from the pressure of the special nut forcing it into the compression fitting. I'd be wary of its ability to both bite and seal a second time. But I'm a newb. John, would you reuse a ferrule?
Several BMWs |
It's a brand new ferrule off of the unused new line that comes in the update kit for post 74 cars.
