Nathan M's Avatar
Question 89 Carrera - do I need to replace head studs
My engine's apart for a valve job. It had done 80000 miles but had excessive guide wear. Should I be replacing the head studs on reassembly?
3.2 Coupe
Old 11-10-2003, 05:14 AM
I would, it's relatively cheap insurance against future problems. Whilw your in there, chain wheels, chains, clutch/pp and all the other wear items should be closely looked at.
Old 11-10-2003, 05:59 AM
Friend of Warren
Nathan, you only need to replace the 12 exhaust side (lower) head studs. They are the dilavar ones. The upper studs are steel and do not have the corrosion problems the dilavar ones do.
Kurt V
Old 11-10-2003, 06:13 AM
Friend of Warren
Originally posted by Wayne at Pelican Parts
If it were my engine, I would also replace the rod bolts too...
-Wayne
I went with the ARP racing rod bolts. Considered it not so cheap insurance.
Kurt V
Old 11-10-2003, 05:26 PM
I always replace all 24 studs in cases like these,......
The steel ones and the latest 993 dilivar ones do expand at different rates and using the 993 studs keeps even torque on the heads from cold to hot.
ARP rods bolts are indeed, a no-brainer,....
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-10-2003, 06:42 PM
993 Dilavar studs? I've been trained to consider the "D" word a profanity around these parts.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 11-11-2003, 09:39 PM
Nathan M's Avatar
My dilavar head studs are not showing any corrosion. I take it this is no guarantee they are OK? Which studs should I replace them with?
With regards to rod bolts, if I go with ARP ones can I safely have the rev limit increased when I have my chip (custom) remapped?
Thanks,
Nathan
3.2 Coupe
Old 11-16-2003, 02:32 PM
Author of "101 Projects"
Wayne 962's Avatar
Thanks,
Nathan
Theoretically, yes. However, most people don't like to push their engines further than they were originally designed to go. It's up to you though...
-Wayne
Old 11-16-2003, 05:05 PM
Hi Wayne:
The latest 993 TT dilavars have been very good and I use them in everything. Steel studs are OK too for early (non-mag) engines that do not get hot,..... They are quite strong and reliable of course, but they cannot accomodate the engine's expansion very well and in the big-bore motors, I see some leakage from the head-to-cylinder surfaces due to bending when hot.
I don't use Raceware or ARP studs any longer due to head loosening issues.
Nathan:
You can turn the engine up to 7100 if you have the ARP bolts but unless you make some cam changes, its rather pointless.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 11-16-2003, 11:19 PM
Friend of Warren
Well I just bought 12 steel head studs to replace the dilavar. Should I send these back and get the 993's? This is on my '86 3.2 engine. Should I buy 24 of the 993's or just the 12 on the exhaust side?
Kurt V
Old 11-17-2003, 07:30 AM
Friend of Warren
bump for an answer to my question.
Kurt V
Old 11-18-2003, 10:10 AM
Nathan M's Avatar
Thanks Steve. I was considering a change to 964 cams. Would this be a worthwhile move and would I it also be worth the extra expense to move to Euro pistons?
I'm still confused as to which head studs to buy, as per Kurts question above. Are the 993 ones all the same material then?
3.2 Coupe
Old 11-19-2003, 01:37 PM
