Installing Valves
Greetings all,
I’m re-assembling my heads after they have been cleaned and measured for wear. My question is do I put any oil or other lubricants on the valve stems when re-inserting them into the valve guides? Although I am going to be putting the heads together now they will probably sit for a month or two until they are actually put back on the motor and run. Last edited by smestas; 11-08-2003 at 02:17 AM.. |
Senior Member
Simon....the pro who re & re'd my 3.0 heads, did put a smear of assembly lube on the valve stems.
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
Author of "101 Projects"
Yup, Walt uses some type of red assembly lube, but I can't for the life of my remember what it's called...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Could it have been Red Line Assembly Lube?
http://store.summitracing.com/product.asp?d=3&s=10&p=4337&searchtype=ecat |
Not sure...
-Wayne
Banned
Red line assembly lube is supposed to be the best and thats what I use. There is another type of assembly lube that is red. I do not remember the name, but I suspect that it is ok as well.
Yes you should lube the valve stems. Use at least white or moly lube or red line if its going to set a while. I guess it may be ok to use just oil if you are going to fire it up withing a few hours. On cam shafts use ONLY red line assy lube or MOLY, no white stuff or oil. If you do not you may not have any cam lobes after a few minutes! |
Not really pertinent to Porsches, but I dumped a quart of oil on top of the twin overhead cams that I just recently installed on my BMW. It kept them very lubricated when I went to start up. Of course, the shafts and lifters weren't dry at the time...
-Wayne
Banned
Wayne,
Please, advise all to use MOLY at a mininum on All camshafts at startup. The initial breakin is critical to camshafts, even on chevys. |
On new parts, definitely use the Moly lube (as shown in my book). I like the LiquiMoly brand. -Wayne
