smestas's Avatar
Send a message via AIM to smestas Send a message via Yahoo to smestas
Installing Valves
Greetings all,
I’m re-assembling my heads after they have been cleaned and measured for wear. My question is do I put any oil or other lubricants on the valve stems when re-inserting them into the valve guides? Although I am going to be putting the heads together now they will probably sit for a month or two until they are actually put back on the motor and run.
Simon Mestas
'78SC Coupe
My Pelican Page | AlfaBB - Alfa Romeo Forum
Old 11-08-2003, 12:43 AM
Senior Member
Doug Zielke's Avatar
Simon....the pro who re & re'd my 3.0 heads, did put a smear of assembly lube on the valve stems.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 11-08-2003, 08:32 AM
smestas's Avatar
Could it have been Red Line Assembly Lube?
http://store.summitracing.com/product.asp?d=3&s=10&p=4337&searchtype=ecat
Simon Mestas
'78SC Coupe
Old 11-09-2003, 10:17 PM
Banned
snowman's Avatar
Red line assembly lube is supposed to be the best and thats what I use. There is another type of assembly lube that is red. I do not remember the name, but I suspect that it is ok as well.
Yes you should lube the valve stems. Use at least white or moly lube or red line if its going to set a while. I guess it may be ok to use just oil if you are going to fire it up withing a few hours.
On cam shafts use ONLY red line assy lube or MOLY, no white stuff or oil. If you do not you may not have any cam lobes after a few minutes!
Old 11-10-2003, 09:04 PM
Author of "101 Projects"
Wayne 962's Avatar
Not really pertinent to Porsches, but I dumped a quart of oil on top of the twin overhead cams that I just recently installed on my BMW. It kept them very lubricated when I went to start up. Of course, the shafts and lifters weren't dry at the time...
-Wayne
Old 11-10-2003, 09:28 PM
Banned
snowman's Avatar
Wayne,
Please, advise all to use MOLY at a mininum on All camshafts at startup. The initial breakin is critical to camshafts, even on chevys.
Old 11-10-2003, 10:51 PM
Wayne 962's Avatar
Originally posted by snowman
Wayne,
Right - that's why I mentioned that the camshafts and lifters weren't dry - meaning that they were used and already 'worn in'. No new camshafts or lifters there.
On new parts, definitely use the Moly lube (as shown in my book). I like the LiquiMoly brand.
-Wayne
Old 11-11-2003, 01:54 AM
