MovOvr1's Avatar
Turbo rebuild
I have been making a shopping list for parts when I drop the engine out of the 79 930 this winter and was looking at the turbo and associated plumbing and is coated with oil. I also found oil in the tube that goes up into the intercooler. The turbo still spins and spools up to where it should but since it is leaking do I just have to get a rebuild kit for it and is it something easy to do?
Also, one of the oil feed line to the turbo that is underneath the car in front of the bumper with what I think looks like a regulator or something on it is leaking pretty bad......what is this?
thanks
Brian
Brian
BLK 79-930
Old 11-15-2003, 07:54 PM
It is normal to have a little oil in the intake plumbing. It isn't that hard to rebuild a turbo, but you have to be very careful not to damage it. Do you have the orig. turbo in your car? If so I would upgrade to a K27 instead of rebuilding the stock one
I am not sure what you are talking about. There is an oil drain sump under the turbo. Is that what you are talking about? Post a pic of it.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 11-15-2003, 09:09 PM
MovOvr1's Avatar
Maybe that is what it is. It is maybe 7" from the turbo. Just a little bigger than a D cell battery in line with the line, but it is leaking pretty good.
Brian
Brian
BLK 79-930
Old 11-16-2003, 12:28 PM
sounds like an aftermarket turbo sump. loose fittings? scuffed thru from rubbing on driveways?
206 637 4071
Old 11-16-2003, 12:55 PM
Or a bad gasket. If it is a bad gasket buy a factory one. I think it is special high temp material
Dean
Old 11-16-2003, 02:45 PM
MovOvr1's Avatar
Do you have a part number for this?
Thanks for input, that sounds about what I think it might be. I wish I had a picture.
Brian
Brian
BLK 79-930
Old 11-16-2003, 07:10 PM
I don't have the part #
Dean
Old 11-16-2003, 07:30 PM
beepbeep's Avatar
If turbo doesn't smoke on overrun and shaft doesn't have excessive play, leave it. There is always oil in intercooler / hoses as it gets sucked up from crankcase ventilation.
Thing under it is turbo Oil-sump. It's commonly dented/scratched when pulling from driveways...your's might be leaking...
Thank you for your time,
Old 11-17-2003, 07:45 AM
Cymru am Byth
carmad's Avatar
If its a stock turbo don't bother rebuilding it get a K27 Hi Flow from Imagine Auto. You will not be disappointed spools quicker and has more oomph than the regular K27.
The gasket you need is part number 930 107 116 00.
The turbo oil drainage reservoir is part 930 107 001 07.
Hope this helps
1986 930 (Gone but not forgotten)
1995 993 (Should Never Have Sold it)
2007 BMW 328Xi Sport Wagon
2005 Lexus GX470 Offroader
Julian Williams
Old 11-17-2003, 01:53 PM
MovOvr1's Avatar
THank you very much. It doesn't sound like I need to rebuild it, but I will look closer when I have the engine out.
Thanks again,
Brian
Brian
BLK 79-930
Old 11-17-2003, 07:58 PM
