P234 flywheel seal tool
Is the P234 tool the correct one for the flywheel seal on a 1995 993 motor - mine looks like it is too small diamter wise to work.
Old 11-22-2003, 05:31 PM
i'll have to check my rubber hammer for that number.
206 637 4071
Old 11-22-2003, 05:51 PM
Ok, I get it - I'll stick to using a rubber hammer or the end of a rachet!
Old 11-22-2003, 11:32 PM
911gilley's Avatar
It would be better to invest in the flywheel seal removal tool, as this is usually where the problems arise.
Ed
_________________________
'95 993 Cabriolet
'83 911 SC Coupe (gone but not forgotten)
'84 944 Coupe (willed to brother)
Old 11-23-2003, 06:17 PM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
Part# 0000.000 = sheet metal screw and a pair of pliers....
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 11-24-2003, 05:36 AM
911gilley's Avatar
A pair of vise grips with a slide hammer welded/rigged to end.
Picture courtesy of 5axis:
Ed
'95 993 Cabriolet
Old 11-24-2003, 05:57 AM
this thing works real well.
206 637 4071
Old 11-24-2003, 08:05 AM
911gilley's Avatar
John,
What is that thing (what application is it originally intended for)? Or did you make it? Looks like it would work by prying against the crank end? I like it. It would eliminate drilling (metal shavings) into old seal metal and scoring/damaging sealing surface!
Ed
'95 993 Cabriolet
Old 11-24-2003, 08:57 AM
Friend of Warren
Originally posted by 911gilley
John,
It's a rubber seal puller. If Pelican doesn't carry them, you can get one at Snap On for around $12.00: http://buy1.snapon.com/catalog/pro_det.asp?P65=&tool=all&item_ID=12192&group_ID=1644&store=snapon-store&dir=catalog
Kurt V
Old 11-24-2003, 09:02 AM
That's what I used - $9.00 at Sears.
Old 11-24-2003, 12:34 PM
911gilley's Avatar
Thanks. Awesome. I'll have to pick one up.
Ed
'95 993 Cabriolet
Old 11-25-2003, 06:10 PM
