Friend of Warren
Honing 3.2 cylinders.
As I progress in my rebuild I will soon have to make a decision regarding my 3.2 cylinders which are Mahle. They have 133,000 miles and are withing specs. The insides look great and still have the factory hone marks. Wayne, in your book you show using a flex hone on the cylinders. I presently have the standard 3 stone hone. Can I use this or should I get a flex hone? If I get the flex hone should I get the 95mm (the size of the cylinder bore) or get one larger (the next size up is 105mm) or should I even hone the cylinders?
Kurt V
Old 11-24-2003, 08:19 AM
Friend of Warren
bump before I repost this on the 911 tech board.
Kurt V
Old 11-25-2003, 07:58 AM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
320 silicon carbide ball hone. Or, just scrub with a scotch brite pad to break the glaze. You're not honing, just cleaning up.
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 11-25-2003, 09:58 AM
