930 Oil pump question
I just recieved a used 930 oil pump that I purchased on this board. When I have it on the bench with the drive shaft attached I cannot get the pump to make one revolution by hand. Seems to to be binding somewhere inside.
Question: Should you be able to rotate an oil pump by hand with smooth action over 360 degrees of rotation and more or does it require more than hand force?
Doesn't seem right to me.
Thanks for the input.
Dana
Old 11-10-2009, 01:13 PM
so take it apart.
206 637 4071
Old 11-10-2009, 01:25 PM
Dana - it should turn by hand
Old 11-10-2009, 01:29 PM
I was hesitant to take it apart because if I did, and found a problem, I would have diminished my recourse with the seller.
Old 11-10-2009, 01:40 PM
Dana
Sometimes, if these have been sitting for a while, they will be difficult to turn by hand. Try connecting the lay-shaft and intermediate shaft to the pump drive. Spray some WD-40 into the pump and use the large gear on the intermediate shaft as leverage to turn the pump by hand. This usually will break it loose and then you can check for nice smooth rotation.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 11-10-2009, 01:54 PM
Thanks. I'll work on it tonight.
Dana
Old 11-10-2009, 02:12 PM
3 restos WIP = psycho
kenikh's Avatar
Yep, fill 'er up with Marvel Mystery Oil, slip on a socket on the shaft and try to turn it with the additional leverage of a ratchet. Go easy.
That should un-gum it, as these pumps rarely, rarely fail, barring other catastrophic engine damage that gets steel shrapnel into it.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 11-10-2009, 05:23 PM
It should turn freely but remember, it turns CCW.
Bruce
Old 11-10-2009, 05:43 PM
Disassembled it (per John) and cleaned it real well. Reassembled and oiled. Seems to be much better.
Now to tackle the #3 main bearing web for it to fit the 7R case.
Thanks to everyone.
Dana
Old 11-10-2009, 06:15 PM
Dana,
How hard was it to put back together? Any special tools required?
I'm thinking of jumping on that used pump on ebay and am curious about how to solve any potential problems.
Landon
Landon
- 1972 911T
Old 11-12-2009, 09:36 PM
Landon,
It is not difficult. I was hesitant only because if I found a problem, I might have had a harder time negotiating the return. Hopefully you won't have to go through that.
Good Luck
Dana
Old 11-13-2009, 05:46 AM
Just in case someone is interested:
Old 11-28-2009, 07:57 AM
