-   -   Re-ring Alusils? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/137346-re-ring-alusils.html)
KTL 01-08-2005 05:20 PM
Originally posted by William Miller
Wasn't there a post about the problems BMW has with Nikasil?
What did they determine was the cause?
I heard they replaced a lot of engines!
Some background on the BMW M60 V8 Nikasil alloy engine block problem courtesy of Koala Motorsports
Nikasil BMW M60 V8 engine block info
starlifter1 01-09-2005 11:10 AM
So if there were to be a suggestion out there on a serviceable set of cylinders would you hone with the “grape “style and use the paste or just one or the other?
snowman 01-09-2005 01:23 PM
I would suspect the results to be the same with either hone. We need to finish the experiment and hone and analyze a cylinder with a grape style hone just like was done with the paste.
KobaltBlau 03-07-2005 12:08 PM
So, I guess PBH never got an alusil from Jerry and sent it to the old-timer, then to Rondinone to have Rondinone measure and EM it? I know, lots of work and lots of links in the chain, but it would be cool to see.
Porsche_monkey 03-07-2005 12:13 PM
No one ever sent me anything. I am still willing to cough up the $15 or whatever if anyone wants to send me a cylinder and someone will measure it.... There isn't even a first link in this chain:)
mike95125 03-07-2005 02:49 PM
I have a spare used one for the experiment. PM me an address and I will send it out. Thanks for doing this!
KobaltBlau 03-07-2005 03:29 PM
I guess to be very consistent it should be one from Jerry st. germaine's set that rondinone used, but that set was pitted and such a wreck I wouldn't think of actually re-ringing them, so maybe it would be better to use a half-decent one like mike presumably has.
smestas 03-07-2005 05:10 PM
Have you guys read Henry Schmidt findings in this thread. Just thought I'd add the link since his data and testing is important to this thread.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/163663-do-i-need-hone.html
KobaltBlau 03-07-2005 08:08 PM
Simon, it's very good info but Henry tested Nikasil cylinders, not Alusil. Still worth linking to, no doubt.
Porsche_monkey 03-08-2005 04:47 AM
Can someone measure one if I get it prepared?
Rondinone 03-08-2005 10:07 AM
I can do the measurements. If you don't mind destroying the cylinder we can take a look with the electron microscope. Otherwise we'll have to settle for a profilometer measurement, which will accurately profile the cylinder wall. Galling will be evident either way, microscopy is easier to interpret.
Porsche_monkey 03-08-2005 10:33 AM
I'll PM Mike 95925 and see if he can mail it to me....
Porsche_monkey 03-24-2005 07:33 AM
My cylinder arrived from Mike95125 today!! Now I feel like a bit of an idiot, shouldn't it be measured before and after 'honing'? I was thinking that he could hone just the bottom 1/2, but that really won't work, since the upper 1/2 should be worn as much.
Rondinone, any suggestions? Should I send it to you for pre-inspection?
William Miller 03-24-2005 07:50 AM
Anybody see the post on the carbon pistons?
I don't know the technology, but it might be an option for those with worn cylinders to go oversized.
If we extend the life of what we have maybe some day there will be a solution so we can keep the alusil cylinders!
kenikh 03-24-2005 08:50 AM
My only concern is that carbon pistons won't transfer heat. Since air cooled cars use the oil to draw away heat via the pistons, that heat most likely will get soaked by the heads and cylinders only. It doesn't sound healthy for the motor. I can definitely see the advantage with water cooled cars.
Rondinone 03-25-2005 07:32 PM
You can send it to me, I'll profile what I can and return it to you. PM me for my address. Thanks,
Rondinone 04-08-2005 07:15 PM
OK I finally measured the compression. 6k miles post rebuild with the AN-30 treatment, all cylinders between 150 and 155 warm. That's almost exactly what it was before the rebuild.
Porsche_monkey 04-09-2005 02:27 PM
Rondinone: It's still underway, just too busy at work....
KobaltBlau 04-10-2005 01:39 PM
good job keeping this moving forward, guys!
Rondinone 04-10-2005 06:00 PM
that's fine. Get it to me when you have time. Thanks,
