Larry Harris's Avatar
Porsche Crest High RPMs
My 85 Carerra shows 3300 RPM at about 75 mph in 5th gear. I would like to lower the rpms to around 2800 @ the same speed.
Can I change the 5th gear ratio. I also have a tired syncro in first gear. Otherwise the trans is excellent. What are other things I should look for/upgrade while I have the trans out.
Larry H
Old 11-30-2003, 03:46 PM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
That's the 915 trans, so the "tired" first gear syncro is probably due to the fact that most of these trans don't like going back into first gear until at a dead stop. Fifth would be much easier to change simply because it only requires opening the back cover off the trans to expose both fifth and reverse. If you really want to replace first syncro than you might as well do the other syncros 2-3 which means it's basically a full trans rebuild.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 12-01-2003, 06:41 AM
Thumbs up Thanks
1fast red sc,
Thank you for the info. I haven't been through New Mexico in many years but I remember the beautiful scenery.
Larry H
Old 12-01-2003, 06:53 AM
