-   -   Snap...crackle...pop...ROAR!! (http://forums.pelicanparts.com/911-engine-rebuilding-forum/137556-snap-crackle-pop-roar.html)
dtw 11-28-2003 05:05 PM
OK, so today I turned the key! And turned it, and turned it, and turned it. After investigating, I discovered that my injectors had pressure and my ignition was sparking correctly, but due to a lack of extra "oomph" from the cold start mechanism (isn't running, don't know why yet), the engine couldn't start. I shot gasoline straight into the intakes with a spray bottle while cranking, and the car fired right up. I discontinued use of the spray bottle, and the engine continued running strong on its own, firing on all six. The sport exhaust is insane. This engine really has an amazing sound - it snarls, growls, and roars. No tinny or raspy sounds at all; its all throat.
So far the only oil leak appears to be from a valve cover. Score!
Needless to say, I'm bouncing off the walls with happiness today. I haven't had a 'running' Porsche 911 since... Jan 2000??? Wow, 4 years. So a shoutout to:
-Pelican forums and the ever-positive Pelicaners
-Dempsey for his engine book
-Tyson Schmidt and John Luetjen for helping to 'design' this engine
-My long-suffering wife
-Tim (aka wrench monkey)
Here's a pic:
http://forums.pelicanparts.com/uploa...1070067600.jpg
Nice eh??
Here's also a photo of the first oil change. Any thoughts, comments, etc? It shimmered with metallic flakes.
http://forums.pelicanparts.com/uploa...1070067674.jpg
89turbocabmike 11-28-2003 06:42 PM
Congrats Dave! There's truly no better sense of accomplishment,no matter how long it takes! I bet it sounded great:)
john walker's workshop 11-28-2003 06:45 PM
cam lube maybe?
Jim Richards 11-28-2003 07:29 PM
Great news there, Dave! Hope those flakes are not of any consequence.
jpnovak 11-29-2003 05:00 AM
The sound of that engine is great. I got a phone call yesterday afternoon with an unmistakable purr mixed with a loud smoothness that only a sport muffler can sing.
Congrats on getting that beast to roar! I guess Its about time to do the same.
Jamie
tfranko29 11-29-2003 05:23 AM
Good job on the rebuild. I bet the roar is satisfying, I thought adjusting my valves was pretty cool!!
Pat S 11-29-2003 06:42 AM
My oil looked the same for the first two times (2nd, not as bad as the first). I also think it was all the assembly lube coming off. After 4 oil changes, it now looks completely normal.
jgparker 11-29-2003 07:08 AM
That oil looks so bad, you'll need to start over on the rebuild... just kidding. I'll bet it smells funny too. That's normal. It's a great feeling, isn't it... That exhaust looks great, I'm sure it sound great too.
power 11-29-2003 09:10 AM
Alway's great to see a MFI roar back to life. I like the comments and look of the sport exhaust. I am considering modifying the two in one out presently residing in my laundry closet, you may have just convinced me!
Halm 11-29-2003 02:37 PM
Excellent Dave! Let us know when you are on the road with it and we'll celebrate by having another Carolina Fun Run. :D
obrut 09-02-2004 08:22 PM
Hi Dave
What are your driving impressions of the sport muffler and MFI engine combo? Any flat spots?
I've heard good and bad for using these mufflers with MFI - especially that they do not have enought back pressure.
Tim Walsh 09-03-2004 05:29 AM
Dave's on his was to allentown today, but I can answer for him after having driven it for more than a few miles. The sport muffler was designed to work well with the MFI. If there is a flat spot at 3K I didn't notice it. He and I LOVE the sound of the sport muffler. It's really pretty tame at idle and without much throttle, but when you get into it it roars to life and has a really mean sound to it.
more later
briankeithsmith 09-03-2004 05:42 AM
My oil looked like that when I changed it the first time, after running it for 15-20 minutes.
Its all the assembly lube.
And yes, it does smell funny.
Tim Walsh 09-03-2004 08:42 AM
Here's a link to a sportmuffler sound file I've got (not this car's though)
www.uncg.edu/~tpwalsh/graywolf001.wav
obrut 09-05-2004 05:16 PM
thanks guys
does anyone know if baffling in the danske 2 in 2 out (centre pipes) is any different than the 'home made' ones people make up from old standard mufflers? (ie. seal the side outlet, add the two centre pipes and cut some extra internal holes)
i ask because old standard mufflers (and welders) are much easier to find in Australia than danske products
dtw 09-06-2004 12:11 AM
Ryan,
As mentioned above, I LOVE the sport muffler. You'll find me around town in mostly 2nd and 3rd gear, just so I can listen to that wonderful engine. I've got an almost-unnoticeable flat spot when transitioning from part throttle on overrun to WOT. It is very difficult to reproduce as the conditions usually aren't right. I don't know if this attributable to the sport muffler, inherent limitations in WWII injection technology, 30 year-old pump needs rebuilding, or 'T' space cam mated to my Crane tuner cams.
NO idea about the Dansk guts. The best thing about building your own sport exhaust from an old muffler, is that the existing baffles are already nice and rusty. They flow better :D
dtw 09-06-2004 12:15 AM
Incidentally Ryan, and those interested, here's a link to 3 recordings of my freshly-built engine with sport muffler. 1st two are in-car, 3rd is a drive-by outside of the car. Great Doppler effect on the last one.
obrut 09-06-2004 04:26 AM
Dave
many thanks - i'm trialling a mate's spare stock muffler on the weekend. if that improves things then i think a dual centre out sport muffler is on the cards. of course - all results will be reported here.
obrut 09-11-2004 06:06 PM
it worked!!
http://forums.pelicanparts.com/porsche-911-technical-forum/182146-mfi-flat-spot-fixed-freakin-sport-muffler.html
dtw 09-11-2004 09:22 PM
Great! Are you going to try converting the OEM Bischoff to a twin-pipe sport muffler now?
